Team : latenights - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 42
Thread: Team : latenights
  1. #13
    Member leftright's Avatar
    Jun 2015
    40 core xeon? I'll sob back to my dual core then... great lighting guys. I've found the only way to get around the photon smoothing / crisp shadows is to edit the .ini file and emit a ton more photons as its still noticeable with 100 bounce 10 quality . 10x photons seemed to be the sweet spot between quality and bake time.
    cheers!
  3. #14
    Jun 2015
    Scotland
    would be nice to see some other areas of your project guys...keep up the good work!!
  4. #15
    Senior Member JurajTalcik's Avatar
    May 2012
    Quote Originally Posted by leftright View Post
    cheers!
    Oh, hmm, perhaps I should touch it. How much time trade-off is it ? Thanks for advice, I might try it if I am brave enough.
  5. #16
    Jun 2015
    Quote Originally Posted by JurajTalcik View Post
    from the tests I did weeks ago I found that tweaking
    NumImportanceSearchPhotonsScale=x - default is 3 for production
    NumIndirectPhotonsScale=x*3
    NumDirectPhotonsScale=y - default is 4 for production
    DirectPhotonSearchDistanceScale=y/8
    gave good results. In terms of time trade off, I'd start by increasing NumIndirectPhotonsScale & NumDirectPhotonsScale by 1 each time until it looks good. That alone takes time but I guess bake times will all depend on your scene and number of triangles. Let me know if you find the magic numbers though
  6. #17
    Administrator bakbek's Avatar
    Dec 2009
    Israel
    When you finish late at night...
    Please make it official by entering this here as well - http://ronenbkr.mn/thevineyardsubmit
    Good luck!
  7. #18
    Aug 2015
    Hey guys!
    Nice work here! I wish you best of luck!
    Veľa šťastia Juraj!
    Best regards
    Előd S.
  8. #19
    May 2012
    I might need it though, merged everything together, and suddenly found lightmaps doing some ugly streaming into horrible mipmaps : /. Edited BaseEngine.ini but it doesn't seem to do anything.
    To what value should this be set ?
    LightmapStreamingFactor=
    High or low ? To eliminate mipmapping. This is what the manual says, I absolutely have no idea what it indicates....
    "LightmapStreamingFactor Extra boost factor for TEXTUREGROUP_Lightmap textures."
  9. #20
    Aug 2015
    Actually we are having troubles with mipmapping too. I hope you can find a good solution. We are currently turning off manually some key textures, at key shots. But yeah, a global solution would be nice.
  10. #21
    May 2012
    Super stressed but going steadily. I still need vinegrape mesh so I might yet open SpeedTree (That freebie does not look suitable for unwrapping given the mesh), and take shamelessly donations if someone feels generous :- ).
  11. #22
    Senior Member
    May 2011
    i would stay away from using lighmass on foliage - exclude them from lm instead and use vertext space ambient occlusion on it, looks a bit flat but the other way it would be pitch black on some areas which you would not want either
    so the freebe thing is quite okish - did not use it ourselves, speedtree is always good optoin
  12. #23
    May 2012
    Fucking matinee doesn't work : / All director tracks are fine, Play/Launch both look perfect yet Matinee Movie shows with something completely wrong...wtf.
  13. #24
    Jul 2014
    Can you record it with shadowplay? It's the best way I've found. Matinee export is always messy.
