The Museum by Juraj Talcik - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 35
Thread: Juraj Talcik
  1. #13
    Jun 2012
    Erlangen, Germany
    I think it should be in the cm range. Maybe 2-5cm but not totally sure.
    Advertising world
  3. #14
    Jan 2010
    Chicago, IL
    Another solution for glass windows I've had success with is using the regular glass material from the wizard (so it will refract, attenuate, etc.) but turn on "hidden to global illumination" in the object properties->Maxwell tab. Though as S.Neadnod found, it will block visibility to zdepth, object id etc. channels that are on the other side of the glass.
  4. #15
    Member tolas's Avatar
    Dec 2009
    Poland
    Quote Originally Posted by JurajTalcik View Post
    Thank you. I would love to keep refraction if possible. My glass is volume geometry, albeit thin. I'll turn off the caustics, as I don't find them necessary. Any idea what the attentuation should be at glass ? I put in 5mm as in glass thickness, but, this is only guess.
    Everything that passes through real glass (volume geo) is considered as caustics as far as I know.
    This means turning off caustics will probably result in weird results, but that of course requires some testing.
    Personally I would use AGS with sun (or any other distant/bright source of light, hard to find by randomly shot samples) and real volume glass with HDRI or skylight (huge area light)
    www.pawelfilip.com
    twitter
    facebook
  5. #16
    Jan 2010
    Chicago, IL
    Here's a link to the maxwell docs about transparency Transmissive Properties - Maxwell Documentation - Next Limit support site
    After reading that I think... Yeah, whatever. I'm more confused than i was before I read it. What I usually do set the attenuation parameter (the one that is a distance) to something like twice the thickness of the glass (which would put it in the range stebehan mentioned above), then set the transmission color to be about 80% brightness with a slight greenish color. It's worked so far, and actually the material wizard is pretty good for getting close. This is for glass that has both sides modeled instead of just a plane.
    At least when using hdri environment lighting, I haven't noticed too much performance difference between AGS glass and regular glass with "hidden to global illumination" checked on.
  6. #17
    Senior Member JurajTalcik's Avatar
    May 2012
    Some update, I'll finish the whole environment today. So far I have Matthias's church, Philharmonie, Bibliotek, Kulturforum, Maritim hotel, few blocks of flats around. Here is Philharmonie. I'll post more progress soon.
Size:  33.4 KBName:  7bw.jpg
Size:  38.3 KBName:  8b.jpg
  7. #18
    May 2012
    Bibliothek, this one is covered by trees mostly, so it's bit more basic.
    Both of these building feature similiar facade, and I am not sure whether they're painted metal plates (IOR of 1.6) or finished metal (high IOR). Anyone to chime on that ?
    And something on different note
    Hmm :- )
    Attached Images Attached Images
  8. #19
    Senior Member
    May 2011
    i am really loking forward to the final result.
    your Mies-Double looks very convincing
  9. #20
    May 2012
    Quote Originally Posted by lasse1309 View Post
    Thank you :- ) I found him at local swimming pool, he is construction engineer
  10. #21
    Junior Member ichi.one's Avatar
    Dec 2009
    Mies doing a cameo like Hitchcock in his movies ?
    or like that Aphex Twin video : every visitor of the NNG has a Mies head
    sorry
  11. #22
    May 2012
    Quote Originally Posted by ichi.one View Post
    sorry
    Kind of :- )
  12. #23
    Senior Member
    May 2011
    Juraj,
    i think the facade consists of gold-eloxated aluminium panels - and i think it is of kind of a rough texture.. there are not many places where you can get close to it though..
    regards
    Lasse
  13. #24
    May 2012
    Thank you Lasse, must be the gold ;- )
    Here is church, not polished like Bertrand, but nonetheless usable :- ) Lacks glass material and roof dirt yet, but will look really good once inserted into whole environment, which I will complete tomorrow. Tomorrow is also finish foliage day.
    This kind of modeling and creating of objects is a bit of novelty for me. First time kind of thing. I made the textures from my sadly low quality photos captured during my trip. Cut them up from photos and played little bit around with copy and clone tools. Applied to simple geometry like vertical planes, and went from there with extrusions and chamfers. I tried to divide everything into modules, which would then tile (mirror actually, but this proved non-working, since Maxwell bitmap manager can only tile texture, what's with that? ). I also took philosophy, that certain elements, like additional dirt to avoid repetition caused by tiling, will be corrected by postwork instead of meticulously unwrapping the meshes. Overall, it's decently fast approach I think..
    bakbek likes this.
